Discussion topic: What is a hub
This message was authored by: Tracy1022
What is a hub
I am on old system essential's what equipment do I have to post back I have internet booster and tv outlet?
Re: What is a hub
A hub is the broadband router.
If you have got to return anything then as a Sky+ box doesn't need to be returned as you own it. Otherwise Sky usually sends packaging out near the end of the cancellation notice period of 31 days for TV or 14 days for Broadband/Talk so if you haven't received it then you can use whatever boxes you have or can get as this link will help you to print the return label and return it via Royal Mail:
https://www.sky.com/help/articles/return-tv-broadband
Add a note inside with your account number and a list of equipment you have included.
Make sure you get and keep proof of posting when sending this off.
