Discussion topic: Volume control through new remote
This message was authored by: Rod8
I am thrying to progaram a new remote and can do everything except adjust volume.
Re: Volume control through new remote
Have you programmed your remote with the correct code for your TV make and model?
https://www.sky.com/help/program-your-remote
Avatar for Rod8
Level 0 icon
Thanmks.  Yes.  It's a JVC TV with a Sky+ box.  Sky doesn't recognise the TV model.  I have tried all the many four digit codes they gave.  One lets me do everything except adjust volume.
It looks like the code you used isn't fully compatible. If you've tried the other recommended codes, there's a final search you could try, which goes through every code stored in your remote to see if there's one that controls volume as well as everything else.
Unfortunately I can't remember the details, but I know they're in @Annie+UK's FAQ. When you have a mo @Annie+UK could you post a link (I wasn't sure if you'd be happy for me to post it)?
See question Q43 in my Sky Plus F⋅A⋅Q
@Mark39 Anyone can link to my FAQ as long as it is for non-proft, as it says at the top of each FAQ page 🙂 😈
Please note: Free (advert supported) Hayu content is available via the On Demand section of your Sky planner, you DO NOT access the free content via the Hayu app!
