6
This discussion topic has been answered Discussion topic: Viewing card
This message was authored by: Goozler01
Viewing card
How to activate viewing card
This message was authored by: Annie+UK Answer
Re: Viewing card
Sky Plus Viewing cards were locked to the box they were paired to at the end of October 2024
Performing a New Install will re-pair a card to the box it is locked to
See question Q21 in my Sky Plus F⋅A⋅Q for New Install
Annie..........
Re: Viewing card
@Goozler01
Do you have a Sky + box and is this a new viewing card ?
Re: Viewing card
@Goozler01
You've posted in the Sky+ board. Is this the same viewing card and same Sky+ box that were paired 12 months ago?
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Viewing card
Annie..........
Avatar for Goozler01
Re: Viewing card
Had to replace hd box with my viewing card it says successfully requested but still not showing my package
Re: Viewing card
@Goozler01
So basically Sky+, being a legacy package, is no longer supported by Sky.
You can't pair a viewing card to any other Sky+ / Sky+HD box that it wasn't paired to at the end of October 2024. This has been asked on here and discussed many times since this policy came into effect.
You can still call Sky to discuss your options which will be upgrading to Sky Q or moving to Glass / Steam to continue to view Sky content through a Sky subscription.
Re: Viewing card
@Goozler01 unfortunately you can no longer pair your Viewing Card with a replacement box. As @Annie+UK posted, your Card is locked to the box in use a year ago.
