Discussion topic: Viewing card not working
This message was authored by: Dave196611
My sky + viewing card is not working.. I can only receive basic channels
Re: Viewing card not working
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q for New Install
Also see: https://www.sky.com/help/articles/viewing-card-error-messages-sky-plus#problem
@Dave196611 Have you, at some point in the past, ordered and cancelled Sky Q?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Dave196611
Yeah, I did over 12 months ago. When the engineer came out he decided it couldn't be connected so was cancelled.
the viewing card is the original one so petty old now.
That could be the reason, although 12 months seems a long time.
Basically when Sky Q is ordered your Sky+ card is set to deactivate at a point in the future. Annoyingly, if the Sky Q install is cancelled, the deactivation can still go ahead. If that's what's happened, you would need to contact Sky to get a new card. You absolutely don't need to switch away from Sky+ even though the agent will try to convince you to.
