Discussion topic: Viewing card faulty sky+HD
Message posted on 23 Jul 2026 03:30 PM
My sky viewing card is not recognised and when removed looks burnt. It is very old and I need to get a new one but can not get round the AI bot.
Message posted on 23 Jul 2026 03:32 PM
Re: Viewing card faulty sky+HD
@Tonyhop1 the brown discolouration is normal and doesn't affect performance. The fault could be either with the Card or your Sky box, so I'd start by turning the box off at the plug, and removing the Card. Clean the card with a fluff-free dry cloth and wait 4 minutes before restarting your Sky box. Once it's up and running, re-insert your Card.
Message posted on 23 Jul 2026 03:33 PM
It is NOT burnt, most cards look like that as they discolour over time
I doubt that it needs replacing
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q for New Install
Also see: https://www.sky.com/help/articles/viewing-card-error-messages-sky-plus#problem
Message posted on 23 Jul 2026 08:11 PM
@Tonyhop1 Have you, at any time in the past, ordered and cancelled Sky Q?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 24 Jul 2026 04:13 PM
Hi all, have carried out power down and restarting and tried the pairing with the BOT that did not change anything. Finally managed to get to speak to someone and have now upgraded for £12 a month less than what I was paying.
Thanks for the replies.
