Discussion topic: Variety package v Stream
This message was authored by: RD1967
I have dish + hd box +variety legacy pack + basic [woeful] broadband.  I have been offered signature package + some extras + much upgraded broadband which all seemed ok until sky/openreach started to give me the riunaround on broadband install date.  I urgently need upgraded broadband very soon.  Being old and not tech savvy is it advisable to opt for sky stream service and a different broadband provider who can install sooner.
Re: Variety package v Stream
@RD1967  If it's a Fibre install then another provider will hit the same delays as they will use the same network.
Sky Stream is a different product to Sky+ and needs a minimum of 25mbps for HD and 35mbps for UHD, if your current broadband service doesn't offer these speeds then getting stream now will result in a poor experience.
Avatar for RD1967
Thanks for reply.    Independent provider have their own cable system throughou my area, so are not reliant on openreach or city fibre,    they are able to connect within a few days,
My questuin is, as I said notbeing very tech savvy, is it straightforward to connect sky stream to another provider's broadband and are there any downsides to sky atream ?
If you are used to using Sky+HD over many years, you will find Sky Stream a very different system. Most notably you can't record in the traditional sense.
If your Sky+HD Box is working fine, my advice would be to stick with it for now.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Sky Stream will work with any ISP, you do not need Sky Broadband. The most important thing is that your broadband is fast, stable and interference free. I used an independent full fibre provider with my Sky Stream puck when I had one and it worked fine.
It's very easy to connect a puck to a WiFi network generated by any router on any ISP. It's up to you to make sure the connection is good enough though - this is potentially a downside for some customers. There is no engineer support for Sky Stream - it can require a bit more troubleshooting from the customer to get and maintain a stable service.
