Discussion topic: U8000f code
Message posted on 23 Apr 2026 08:01 PM
U8000f code
Hi. I hope someone can help me. I've just bought a samsung u8000f 55" tv. I've tried all the codes and none are working. When i press the right button to change the channel on sky it knocks it straight off the hdmi and back to tv. It's SO important to get this sorted as my disabled daughter uses the sky remote for her music channels and she's devasted. Sky + Hd box. Thank you 🙏 x
Message posted on 23 Apr 2026 08:02 PM
Re: U8000f code
How to program your remote control with no code.
Take a look at the link below:
See question Q43 in my Sky Plus F⋅A⋅Q
Message posted on 23 Apr 2026 08:08 PM
Re: U8000f code
Thanks still the same problem . Volume doesn't work and right button knocks out of hdmi and back to tv 🥺
Message posted on 23 Apr 2026 08:11 PM
Re: U8000f code
You could not have gone through ALL 9999 codes in that short amount of time 🙃️
Message posted on 23 Apr 2026 08:13 PM
Re: U8000f code
😅 I've tried a LOT. They're all doing the same thing. I'll keep trying x
Message posted on 23 Apr 2026 09:03 PM
Re: U8000f code
@Trishmac I'd suggest starting again, after resetting your remote by progamming it with code 999. That should stop the problems you're currently having with it
Message posted on 23 Apr 2026 09:04 PM
Re: U8000f code
Hi.. do you mean doing all the other steroids I've been trying with 4 digit codes and using 999 instead? X
Message posted on 23 Apr 2026 09:05 PM
Re: U8000f code
Steps* sorry 🤦
Message posted on 23 Apr 2026 09:22 PM
Re: U8000f code
@Trishmac code 999 will reset the remote to its factory condition - there's then no code programmed for your tv. If a right cursor press then still takes your tv back to terrestrial tv, it's probably faulty.
Message posted on 23 Apr 2026 09:24 PM
Re: U8000f code
Thank you. I'll try that. 🤗X
