Discussion topic: Tv wont connect
Message posted on 09 Feb 2025 02:55 PM
Tv wont connect
I can turn on Netflix but I can't receive tv channels. I get a message: 'Chech the aerial cable connection and chec saved channels.'
Message posted on 09 Feb 2025 03:06 PM
Re: Tv wont connect
@TV13 wrote:I can turn on Netflix but I can't receive tv channels. I get a message: 'Chech the aerial cable connection and chec saved channels.'
That sounds like a message from the TV rather than the Sky box. In which case you need to make sure you are viewing the correct HDMI port that your Sky box is connected to on the TV.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 09 Feb 2025 03:07 PM - last edited: 09 Feb 2025 03:08 PM
Re: Tv wont connect
You cannot get Netflix with Sky-! Have you posted in the correct forum?
Message posted on 09 Feb 2025 03:14 PM
Re: Tv wont connect
Well Netflix is working but tv is not - I can't get the tv menu back.
Message posted on 09 Feb 2025 03:22 PM
Re: Tv wont connect
Netflix through a television app would function when there's no input from either an aerial or a Sky box.
Message posted on 09 Feb 2025 03:23 PM
Re: Tv wont connect
You're watching Netflix via your TV, not your Sky box. You need to change the input source to the one your Sky box is connected to, in order to watch Sky, as @oj01 posted. Look for a button on your TV remote, marked input or source or AV
