Discussion topic: To get upgrade on sky box
Message posted on 20 Jun 2025 11:00 AM
Have had old sky + box for many years. Would like upgrade to newer box
Message posted on 20 Jun 2025 11:06 AM
Re: To get upgrade on sky box
You will need to contact Sky to upgrade to Sky Q (if that's what you mean by a newer box).
I will cc in one of the other Superusers who has compiled a very helpful guide for those thinking of transitioning from Plus to Q which may provide some insight into something you hadn't considered.
cc
Message posted on 20 Jun 2025 12:29 PM
hi @Chris557
As @Daniel0210 mentions, you may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
Message posted on 20 Jun 2025 05:55 PM
'Newer' Sky+ / Sky+ HD boxes aren't available to existing subscribers: it's an end of life product which hasn't been manufactured for nearly a decade, and the old trick of buying a second-hand box and transfering the Viewing Card over no longer works.
