Discussion topic: Technical issues
This message was authored by: Dawn108
Technical issues
Main tv, can't record, pause, message - service not available problem with hard disc drive. Second to, no satelite signal
Re: Technical issues
The Hard disk issue may be temporarily fixed with a FSR
See question Q15 in my Sky Plus F⋅A⋅Q
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
