Discussion topic: Technical issues: no satellite connection, what do I do
This message was authored by: Amina22
I have this message that says that my sky box is not getting a satellite signal
Re: Technical issues: no satellite connection, what do I do
@Amina22
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to; check / realign / repair / replace the dish, perhaps repair or replace the LNB if that's the problem, or check the cables for water ingress.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previously posted on here that they wouldn't send an engineer - but they did offer the customer £ 65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream. If you upgrade to Sky Q any dish, LNB or cable issues would be sorted out f.o.c as part of the process.
▪️I AM NOT A SKY EMPLOYEE ▪️
