Discussion topic: Technical fault
This message was authored by: Mrskamaljeet
Technical fault
Technical failure
Avatar for Mrskamaljeet
Level 0 icon
Re: Technical fault
We dont have any sky programs as it keeps coming up 25
Level 0 icon
Re: Technical fault
Can you please sort this problem as implying regularly
Re: Technical fault
Sky+ error 25 is usually associated with a satellite signal problem. Check by keying Services > Settings > Signal  on your Sky remote. The white part of all four  bars must be at least half way across.
Re: Technical fault
@Mrskamaljeet
As you are talking to other customers in
here I would suggest doing a planner rebuild:
Press Services on your remote
Select Help
Select Sky+ Rebuild
This should take no longer than 10 minutes, don't do it if you are recording or due to start recording something. Your recordings and downloads are safe when doing this.
