Discussion topic: Technical fault. Please try again later
This message was authored by: Janice48
Since yesterday I cannot watch live tv. It says this is a technical fault. Please try again later. This morning I have turned off if I and put it back on and same for tv but still nothing
Re: Technical fault. Please try again later
You've posted in the Sky+ forum, but this doesn't sound like a Sky+ set top box problem. Do you have Sky Stream or Glass?
This message was authored by: NeilRiddy
I get the same
@NeilRiddy in that case, see my reply to the original poster.
