Discussion topic: Sky tv issues
This message was authored by: CraigWatson
Sky tv issues
My sky isn't working it says no satellite signal I think the wind has moved my satellite
Re: Sky tv issues
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Re: Sky tv issues
I would say you're probably right. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you would need to engage a local satellite engineer or installer to take a look.  Alternatively now might be the time to consider upgrading to Sky Q.  Your dish and cabling will be checked at no additional cost to you as part of the installation.
Re: Sky tv issues
I presume you mean satellite dish rather than your own satellite, which would be impressive.
