Discussion topic: Sky to box won’t work
This message was authored by: Lesmand
I resently changed my contract since the the sky box doesn't work
it started by saying no satellite signal so I turned everything off and unplugged it now it says box installing please wait
Avatar for Lesmand
Level 0 icon
Re: Sky to box won’t work
No reply from you
@Lesmand welcome to this customer Community. We're mainly customers here and this is not a live chat with Sky.
The cause of your 'no satellite signal' problem is most likely a fault with your dish or cables. Your Sky box can't initialise unless it's receiving a signal from your dish. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you
What was the change?
