Discussion topic: Sky signal
This message was authored by: Jason135
Sky signal
Sky signal keeps cutting out and flashing up error - time to cancel sky I think
Re: Sky signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
Re: Sky signal
To cancel, give Sky a call. 31 days notice required.
