Discussion topic: Sky scamming SKY HD+ customers
This message was authored by: JTBSKY
Why is it that pretty much since Sky  announced Sky HD + boxes  were no longer supported my signal has got worse on my 3 HD boxes - interesting that - may be trying to acquire more Sky Q customers or am I simply a misinformed cynic ?
Re: Sky scamming SKY HD+ customers
I can't tnink of anything Sky can do to affect the strength of the signal reaching your Sky boxes. Either there's a fault with your Sky boxes (unlikely) or with your dish setup.
@JTBSKY  And you do realise that Sky have no control of the satellites in orbit, nor can they effect it's signal strength.
Not sure how you came to the conclusion Sky are scamming you?
@JTBSKY As it's affecting all 3 boxes, a simple dish alignment issue would seem most likely or a failing LNB. Unfortunately, you'll need a local satellite engineer to investigate and fix.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Stormy weather around the country has caused a lot of dishes to be moved slightly, the forum has had an increased number of reports
But I guess most people moaning will blame Sky for the weather 😞
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
