Discussion topic: Sky saying no signal
This message was authored by: Jistin
Hi
My sky + is saying no signal out of the blue can anyone help please?
Kind regards
Re: Sky saying no signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Avatar for Jistin
Hi Annie
Thank you so much for your reply.
I have actually fixed it now...I suspect it was wires in bk as tried everything and no signal..anyway swapped feed round and pushed and twisted wires while putting bk in and came on.
Thank you anyway and have a lovely evening
Kind regards
  • Justin
