Discussion topic: Sky remote
This message was authored by: Simonxxx
Sky remote
All the buttons are working on my sky remote except the record button.
Can it be repaired or need a new one as I'm recording manually atm not ideal
Re: Sky remote
Check out my Sky Plus FAQ for instructions for cleaning the internals of the remote control
Re: Sky remote
I have a sky+box the sky remote number 8 isn't working I have inserted new batteries any ideas welcome.
Re: Sky remote
Either clean it, as per @Annie+UK's post immediately before yours, or replace it. You can buy a new remote via Sky or an online seller such as Amazon, or in many cases via your local supermarket or hardware store.
Re: Sky remote
Need more info clean it were around the number and  no I don't want to purchase another remote
Re: Sky remote
@Anonymous
You did say any ideas welcome! As suggested clean the remote carefully as there might be a bit of dirt/dust stuck under the button.
Re: Sky remote
Did you read @Annie+UK's FAQ?
