Discussion topic: Sky plus stopped working
This message was authored by: David591
Was watching lingo this afternoon when sky + stopped working it started re-booting from scratch then after a few seconds screen flashed and it just went blank. I have unplugged it for an hour tried again it started up saying sky + initiating then did the same again.
Re: Sky plus stopped working
That doesn't sound good. Try updating the firmware: switch off at the plug for 4 minutes. Then press and hold the Backup button on top of the box while turning on again - keep the Backup button pressed until the lights on the front panel flash. Then release the button and follow the instructions on screen.
Sounds like you'll need to purchase a second-hand replacement or move to Sky Q/Glass
Yep, I suspect @Annie+UK's right.
Avatar for David591
Great - how do I go about that since everything's done by keyboard nowadays and u can't seem to find a human to actually speak to
Avatar for David591
Thanks mark I shall try that now 🙈
Avatar for David591
Not getting anything when trying that mark no lights flash and nothing on screen
Give it a few tries - it doesn't always work first time, but increasingly it looks as the box has had it, I'm afraid.
Avatar for David591
Ok I'll try it again - thanks anyway
