Discussion topic: Sky plus has no signal
This message was authored by: isearle11
Sky plus no signal
Re: Sky plus has no signal
@isearle11
If you’re seeing a message displaying ”No signal” it tends to be from your TV, such as possibly not being on the correct input (check the HDMI cable between the Sky box and your TV)
Whenever a “no satellite signal” message is displayed, that relates to your Sky box, so firstly check that the connections from the Sky dish going into the back of your Sky box are still finger tight.
If it's a dish issue Sky no longer support Sky+ and Sky+HD so won't send an engineer. If you have Sky Protest through Domestic and General Insurance you can call them otherwise you'll need to employ a local satellite engineer at your own expense (or upgrade to Sky Q or change to Glass / Stream).
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
