Discussion topic: Sky plus box broken
This message was authored by: MikeGillett
Sky plus box broken
Can't connect router
Re: Sky plus box broken
If you want help could you possibly add some details
More details are required as those 3 words don't help ?
What happens when you try to connect the router ?
Are you connecting it via a cable or is your Sky+ box a wireless one or are you using a wireless adaptor ?
Has it been working up to now ?
