Discussion topic: Sky+ message - box is still initialising, return later - not recording
This message was authored by: Minime7
When I search for a programme and then try to record it, I am getting a message saying "Sky box is still initialising, return later to this feature.  This only started to happen two days ago.  I have tried unplugging the box and have even done a Sky rebuild.  It does appear to be working when I try to record programmes from the channel listing. Any advice would be appreciated.  Thanks
Re: Sky+ message - box is still initialising, return later - not recording
What are your Signal Strengths/Qualities? Take a look at the link below:
Question Q11 in my Sky Plus F⋅A⋅Q
This can be caused by  one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out sky or a 3rd party satellite/aerial company
Note: If you have a communal dish then this is maintained by your landlord/building management and NOT sky
