Discussion topic: Sky hd+ Satellite signal constantly dropping
This message was authored by: Joolsc1
Sky hd + keeps dropping.  Really annoying. Had sky for nearly 25yrs , had the odd problem like this bit this is constant lately.
Done all the reset etc etc. Still no joy
Re: Sky hd+ Satellite signal constantly dropping
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
