Discussion topic: Sky box
Message posted on 14 Dec 2025 04:25 PM
Sky box
Need my sky box updated/. Replaced
Message posted on 14 Dec 2025 04:30 PM
Re: Sky box
Whats wrong with it?
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
Message posted on 14 Dec 2025 04:31 PM
Re: Sky box
@Vonnie9 wrote:Need my sky box updated/. Replaced
Give Sky a ring if you want to switch to Sky Q.
Message posted on 14 Dec 2025 04:41 PM
Re: Sky box
What is sky q
Message posted on 14 Dec 2025 04:44 PM
Re: Sky box
@Vonnie9 Sky Q is Sky's current satellite tv system (Sky+ is obsolete).
Message posted on 14 Dec 2025 04:45 PM
Re: Sky box
What's the number for me to speak to somebody?
Message posted on 14 Dec 2025 04:48 PM
Re: Sky box
@Vonnie9
These are the current methods for contacting Sky, and some will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
Message posted on 14 Dec 2025 04:59 PM
Re: Sky box
