Discussion topic: Sky box
This message was authored by: Ccuward22
Message posted on 12 Sep 2023 01:01 PM
Sky box
My sky box for a while has been playing up eapecially when turned on picture is not loading up is blury i have to switch off then put on and second time round is usually ok
Find out more
Message posted on 12 Sep 2023 01:25 PM
Re: Sky box
That's an unusual 'symptom'. Most issues clear when you switch off at the plug for 4 minutes. If yours continues to do the same, it may have developed a fault. The most recent Sky+ boxes are at least 7/8 years old, so it may be reaching the end of its life and need replacing.
