Discussion topic: Sky box wont record
This message was authored by: Kaz610
Sky box wont record
Sky + box wont let me record,and channels keep going off saying theres no signal
This message was authored by: HeathHayle
Re: Sky box wont record
might be the LNB that needs looking at the bit with the white thing on your dish does it happen on all channels? if you put it on a channel that works and then try and record does it record?
= Sky+ SD boxes x4 (pace bskyb 3100) ===
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/.or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
