Discussion topic: Sky + box won't turn on
This message was authored by: Brody421413
On light keeps turning between red and Amber, the blue central light is slowly flashing on and off
Re: Sky + box won't turn on
Try a software update, if that fails then try a FSR, if they all fail then the box most likely need replacing 😞
See my FAQ
@Brody421413 I wonder if you may inadvertently have selected Demo mode in your Sky box settings. I can't remember where the setting is, but if you can't find it I'll try to check tomorrow.
Good call, that happens so rarely but could be it
Edit: After re-reading the description of the issue I'm begining to think it is not Demo mode as this spins the blue circlue and the 4 LEDs would be on, I would have thought the OP would have mentioned them
