Discussion topic: Sky box was working other sky box is fine switched it off and back on it starts up but then no signa
This message was authored by: Jedfrom
New WiFi router installed
sky box working fine then tried to install new wifi
it worked on main box and we still have sky but the other box will not work
switched it and off
Taken card out but no response
whem switching it back on light goes green straightaway no red standby
help please
Re: Sky box was working other sky box is fine switched it off and back on it starts up but then no s
Sounds like the box has died. no Sky+ or earlier boxes have been made for at least 8 years, so some are getting to the end of their serviceable lives
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
Avatar for Jedfrom
Thanks for replying but when we switch it on it does start with the start up menu
SKY HD + on a black screen
A black screein showing Sky+HD in white sounds like ithe box is trying to perform a sorftware update, that can happen if the backup button on the top of box is stuck down, If I understand what you are saying correctly
You could try forcing a software update, see my FAQ, this will not do any harm
BTW, We can only provide help with the info provided, so the more info you provide the better we can guess what is wrong 🙂
Avatar for Jedfrom
Brilliant that worked pressed all the top button
non seemed sticky but next time it rebooted it worked
thank you very much
