Discussion topic: Sky box replacement
This message was authored by: Pearlnthiyane_
Sky box replacement
I'm currently using sky + HD box. I got a letter saying I need to upgrade to sky q because my old sky box will stop working at some point. I've been trying to talk to someone to assist me getting it delivered.
Re: Sky box replacement
@Pearlnthiyane_ Sky Q box is installed by a Sky engineer as it requires an alteration to be made to your dish. Does the letter not include a contact number?
@Pearlnthiyane_
I will cc in one of the other Superusers who has compiled a very helpful guide for those thinking of transitioning from Plus to Q which may provide some insight into something you hadn't considered.
cc @nigea99
hi @Pearlnthiyane_
As @Daniel0210 mentions, you may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
Avatar for Pearlnthiyane_
Thank you for replying. Yes there is a number. I called and the Ai told me to go to the sky website and get it sorted there. This is why I ended up here. I'm going try calling the number again on Monday.
@Pearlnthiyane_ When you call again, try simply not responding to the AI bot. Just wait on the line.
Thank you.
This message was authored by: skygirl1
Sky has sent me a pack sky box and nit a sky Q box how fo i add that package to my account
@skygirl1
Do you mean you've received a Stream puck?
If so then it's s a replacement for Sky+ (if this is what you were using previously)
Sky doesn't permit platforms to be mixed.
