2
This discussion topic has been answered Discussion topic: Sky box problem
This message was authored by: Mand68
Sky box problem
Message displayed
your sky+HDbox isn't getting satellite signal. However I can access Natflix, Prime, Disney, BBC player C4 etc
This message was authored by: Annie+UK Answer
Re: Sky box problem
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Re: Sky box problem
Re: Sky box problem
@Mand68 wrote:
Message displayed
Your Sky+HD Box gets it's signal via the satellite dish. The others are streaming services delivered via your broadband.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
