Discussion topic: Sky box not working
This message was authored by: Mike5303
Sky box not working
Our sky box is not working.
It says we have no signal.
We have tried restarting several times.
All we can get is the Sky News channell.
We have no weather problems at the moment
Re: Sky box not working
@Mike5303
Is this for Sky+ (where you've posted)? Is the error message no signal or no satellite signal ?
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/.or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
Avatar for Mike5303
Sorry,  no satellite signal!!
@Mike5303
Then as @Annie+UK has indicated I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to; check / realign / repair / replace the dish, perhaps repair or replace the LNB if that's the problem, or check the cables for water ingress.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previously posted on here that they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
