Discussion topic: Sky box not working
This message was authored by: JonF69
Sky box not working
No signal on some channels and won't connect to WiFi
Avatar for JonF69
Level 0 icon
Re: Sky box not working
Sky box not working
@JonF69 I assume that's no satellite signal. If you've had snow, that might be the cause and once the snow has gone the signal should return.
Is the wifi problem new? Has it connected before?
@JonF69
If it is a no satellite signal and it's not snow on the dish then I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to; check / realign / repair / replace the dish, perhaps repair or replace the LNB if that's the problem, or check the cables for water ingress.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previous posted on here stated they wouldn't send an engineer - but they did offer the customer £ 65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
This message was authored by: bbargery
I can watch Sky Go on my kindle
