Discussion topic: Sky box not working
This message was authored by: Cathedral
Sky box not working
Sky box is making channels jump no constant channels and signal is very poor
Re: Sky box not working
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
