Discussion topic: Sky box not working
This message was authored by: Christo_2025
Sky box not working
Sky box not turning on Just red light flashing on box
Re: Sky box not working
You could try turning the box off at the plug for 5 minutes, but a flashing red light usually means the box has failed., I'm afraid.
You'll need to upgrade to either Sky Q or Stream.
Flashing red LED can indicate a power supply failure, if this is the case the box is toast 😞
