Discussion topic: Sky+ box no signal
This message was authored by: Clare1981
Sky+ box no signal
Hi all, my Sky+ box is saying no signal, so i think its run its course.  The block of flats i live in doesn't accommodate Sky Q. Is Sky Glass the only other available alternative?
thank you
Clare
Re: Sky+ box no signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
@Clare1981
Research Stream and Glass. It's a totally different thing to satellite television. Glass is basically Stream built into a new TV. You'll need sufficient broadband for both.
@Clare1981 have you spoken to your building management people or a neighbour who has Sky+? This is more likely to be a fault with the communal system your Sky box is connected to, than the Sky box itself.
