Discussion topic: Sky + box keeps losing signal thinking of changing to sky stream
This message was authored by: chrissy32123
Our box glitches and part records constantly, even when the weather is glorious outside!!  was thinking of changing to sky stream but it seems impossible.  Anyone done this? thanks in advance.
Re: Sky + box keeps losing signal thinking of changing to sky stream
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@chrissy32123 It may just mean the box is on its last legs... second-hand Sky+ HD boxes are relatively cheap online🤔
What issues are having getting Sky Stream?
