Discussion topic: Sky box continuing to initialise
Message posted on 06 Dec 2025 09:34 AM
Sky box initialing continuously
Message posted on 06 Dec 2025 09:39 AM
Re: Sky box continuing to initialise
Please repeat
Message posted on 06 Dec 2025 09:41 AM
@Christopher67 it's stuck on initialising because your box isn't receiving a signal from your satellite.lite dish.
The cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
