Discussion topic: Sky Q Box versas Sky+ Box
This message was authored by: MICKEDJONES
I have a Sky+ Box  , but I am considering taking up the offer of a Free Sky Q Box, however I  have now discovered that the techician who installs it ,will fit a New LMB to my Satellite Dish.The Query I have is ....at present I have two other TVs, in bedrooms for guests and grandchildren, connected to the present LMB  and receiving programmes via FreeSat  Boxes ,  BUT  if I change to Sky Q can I still  connect  to  the two tap offs so that I can  still receive Freesat  in the two bedrooms ?
Re: Sky Q Box versas Sky+ Box
Your Freesat boxes need to be wideband to use a Sky Q LNB, also I'm not sure how many outputs the LNB has
You might need a 3rd party to install a hybrid LNB before you get Sky in to upgrade
Please note: Free (advert supported) Hayu content is available via the On Demand section of your Sky planner, you DO NOT access the free content via the Hayu app!
Avatar for MICKEDJONES
Thank you
This message was authored by: ThePope27
@Annie+UK @MICKEDJONES
Buy a hybrid lnb 2x4 and ask the sky engineer to install it when he installs Sky Q 🙂
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
hi @MICKEDJONES
You may wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
As per those notes SKY may consider supplying & fitting a Hybrid LNB where you already have Freesat boxes in use, if you discuss but they are becoming more reluctant to do so, thus as the others say if you do decide to upgrade then it may be worth buring your own Hybrid LNB and getting the engineer to install that
Many Thanks to you all, for your help and advice. I am fully in the picture now.
