3
This discussion topic has been answered Discussion topic: Sky Plus box query
This message was authored by: Ant2099
Sky Plus box query
I had an email saying my Sky Plus box will no longer receive software updates and I can upgrade to Sky Q. Only problem is, where I live we are unable to get Sky Q as we have tried this last year.
Would the Sky Plus box carry on working etc if it is left and I'll continue to get all my channels?
Many thanks,
Ant
Re: Sky Plus box query
If it's Sky+ HD, then yes, as far as we know.
Sky+ before HD (SD-only boxes) becomes essentially unusable later this year.
https://www.sky.com/help/articles/sky-channel-upgrade
@Ant2099
Press Services on your Sky remote
Press 4 then 5
Check the version number below.
The affected boxes are:
Digibox
4F01 to 4F08 (Amstrad)
4E01 to 4E05 (Grundig)
9F01 to 9F08 and 9F0A (Pace)
0F01 to 0F05 (Panasonic)
4E06 to 4E08 (Thomson)
Sky+
4F2001 to 4F2006 (Amstrad)
4F2101 to 4F2118 and 9F2101 to 9F2137 (Amstrad or Pace)
9F2001 to 9F2024, PVR2, 9F2201 to 9F2235, 9F2301 to 9F2339 (Pace)
4E2101 to 4E2141 (Thomson)
Avatar for Ant2099
Level 0 icon
@TimmyBGood
Thanks for the quick reply.
Mine is a HD box, number is 4F3136
So looking like it should be ok for a while anyway as it stands.
Thanks again, much appreciated
