Discussion topic: Sky HD not working
This message was authored by: mjs1975
Sky HD not working
So I came in from work this evening, switched everything on, including my Sky box.
After more than 5 minutes I go to watch something and I'm greeted with a message "Your box is still initialising, please return in a short time to use this feature."
I retrun a short time later and I still get the above message, so I leave it for a bit.
Then the message changes to "Your Sky+HD box isn't getting a satellite signal.  Your recordings in the Planner and the On Demand service may still be available."
I am unable to access my recordings and the On Demand services.
I have switched off and on again a few times, no joy.  Checked the dish and cables, everythings just how I left it this morning.
I am hoping this is similar to that Sky Q issue a few weeks ago
Anyone got any ideas?
Re: Sky HD not working
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
It won't be.
Avatar for mjs1975
It sort of, kind of, was.
My Sky didn't come back at all last night, so switched it all off and went to bed.  Got up this morning, and it came on as normal.  Can't think of any reason why it wouldn't work yesterday though.
Did you have much rain yesterday prior to the issue?
One fairly common occurrence on older setups is water ingress into the cables at the dish end causing signal problems. As it dries out the signal returns. If this is the problem, it will happen again.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
