Discussion topic: Sky+HD demand not working
Message posted on 24 Nov 2025 07:17 PM
My Settings/Network/Connection to On Demand says OK as does Connection to Broadband Router until I try to access On Demand. Then I get a page saying Connect your Sky+HD box to broadband.... and when I go back to the settings page the Connection to On Demand is changed to FAIL.
Have tried rebooting everything and resetting everything but no change.
Any help greatfully received.
Message posted on 24 Nov 2025 07:59 PM
Re: Sky+HD demand not working
@Roy641 has it worked ok before? Are you connected over wifi? Does the everything you've rebooted include your broadband router?
Message posted on 24 Nov 2025 10:09 PM
Yes, it has worked before and yes I rebooted my router and the sky box. The sky box is plugged into a wifi mesh box via an Ethernet cable. I've rebooted that also.
It's odd that the broadband connection is reported as OK, it's just the on demand that isn't working.
Message posted on 25 Nov 2025 09:05 AM
@Roy641 I wonder if it doesn't like your mesh network. You could try a temporary direct connection, either ethernet or WiFi, direct to your router?
Message posted on 04 Dec 2025 11:08 PM
It tured out to be an IP Address conflict. Changing the IP Address of the sky box fixed the problem. Thanks for your help.
