Discussion topic: Sky + HD code for TCL TV
This message was authored by: Maki
Hi - Just bought
TCL S5400AK 32" TV - have tried several recommended codes to pair Sky + rev 9f remote - no luck 😞 Please can anyone help ? Thank you
Re: Sky + HD code for TCL TV
How to program your remote control with no code.
Take a look at the link below:
See question Q43 in my Sky Plus F⋅A⋅Q
Avatar for Maki
Thank you Annie - unfortunately not working. But I've bookmarked your fantastic page !
If you have used the process I pointed to you FULLY, then your remote has no code for your TV as the process will try EVERY single code stored within the remote
@Maki you might have more luck with the most recent Rev10 remote, but there's no guarantee of a code which will work, so a bit of a gamble.
Avatar for Maki
Hi Mark39 - Thank you for your reply. I just contacted a Rev 10 seller on eBay who says it's not compatible with my TV. He's a specialist - loads of remotes, and 99.9% feedback so I believe him !
Ah well - I'll keep looking....
