Discussion topic: Sky + HD box recording issue
This message was authored by: Doc5907
Hi there,
Had an old Sky +HD box that I gifted to family friend. I had it since new from sky since 2015 and only used 6 months and then in storage.
Since they fitted the box they came back to me with an issue in thier words "wont record the program your recording when you are watching another channel, checked all cables and its connected ok"
Any idea what the issue could be and possible solution or could the box just be faulty ? Its strange as it did work perfectly before.
Thanks in advance 🙂
Sky Q 1TB UHD
LG TV
Sky Mobile
Re: Sky + HD box recording issue
Hi @Doc5907 that does suggest it may not have a signal on one of the dish cables. What does the satellite signal strength show (Services > Settings > Signal).
The white part of all 4 bars should  be at least half way.
Avatar for Doc5907
Level 13 icon
Thanks @Mark39  have asked them to check
Sky Q 1TB UHD
LG TV
Sky Mobile
