Discussion topic: Sky HD + Not getting a signal
This message was authored by: GP11
Sky + HD box isn't getting a satellite signal v
Re: Sky HD + Not getting a signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
