Discussion topic: Sky Channel 5 reception.
This message was authored by: StephenG04
Cannot receive Channel 5 on Sky.  Sky indicates "Mini TV Unavailable No Satelite Signal".  Channels 1 - 4 can be received normally on Sky.
Re: Sky Channel 5 reception.
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
It's likely to be a dish alignment issue, even if only the Channel 5 group are affected. The frequency they broadcast on is often one of the first to be affected if the dish becomes slightly mis-aligned.
Are 5Star, 5USA, 5Action affected too?
