Discussion topic: Sky Box won’t connect to WiFi
Message posted on 25 Dec 2024 08:55 PM
My Sky+ HD box won't connect to my Sky Broadband. I've run a network test and all working fine, but when I try to connect it on Sky it says 'No wireless networks found'.
Message posted on 25 Dec 2024 09:02 PM
Re: Sky Box won’t connect to WiFi
Has it connected to your broadband service before? Are you connecting over wifi? Or by ethernet cable?
Message posted on 25 Dec 2024 09:21 PM
I am not sure
Message posted on 25 Dec 2024 09:36 PM
Does your Sky box have a WPS button on the front panel?
Message posted on 25 Dec 2024 10:51 PM
Yes it does
Message posted on 26 Dec 2024 02:24 PM
Press the WPS button on your Sky box and within 30 seconds press the WPS button on your router (Hub). That should allow your Sky box to connect over wifi.
