1
This discussion topic has been answered Discussion topic: Signal
This message was authored by: Jackie19641
Signal
Tv was working as normal then about an hour ago screen went blank., and is saying your box is not getting a satellite. Have switch it off restarted snd still nothing
This message was authored by: Annie+UK Answer
Re: Signal
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
Re: Signal
