Discussion topic: Signal
This message was authored by: Kirkie2
Message posted on 27 Feb 2026 02:53 PM
Signal
We have an issue with getting signal on some channels not
Find out more
Message posted on 27 Feb 2026 03:00 PM
Re: Signal
@Kirkie2 the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
