Discussion topic: Signal keeps breaking up sometime no bbc1
This message was authored by: Rogerwilliams1
Getting  sky tv better signal
Re: Signal keeps breaking up sometime no bbc1
You could try restarting your Sky box by switching off at the plug for 4 minutes.
If that doesn't help the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
